查看: 2519|回复: 3
T.VST26.3B 10104, Panel: V216B1-L01
发表于: 2016-12-9 01:37:45
Resolution: 1366x768, a WXGA
the Display-Mode: the TN, Normally the White, Transmissive
the Active Area: 477.417x268.416 mm
the Brightness: 400 the cd / m2
the Contrast the Ratio: 800: 1
Display Colors: 16.7M (6-bit + Hi-FRC), CIE1931 72%
the Response Time The: 1.3 / 3.7 (Tr of / the Td)
the Frequency: 60Hz
the Lamp the Type: 4 pcs Driver Without the CCFL
the Signal the Interface: the LVDS (1 ch, 8-bit), 30 pins
Voltage: 5.0V
发表于: 2019-5-4 11:35:47
Thank you
发表于: 2019-5-7 20:08:11
Thank you
GMT+8, 2024-4-17 01:20 , Processed in 0.051774 sec., 9 queries .
