查看: 20764|回复: 87
小米L48M3-AA主板维修总结
发表于: 2018-5-23 16:25:37
小米电视2S 48寸,型号为L48M3-AA,板号:DKTV-E-55-928-AE-20150129.
主芯片采用MSD6A928HP-8-002X,CPU Cortex A17四核1.4HZ主频,GPU Mall-760 MP44+4核。
DDR状态为DDR3,采用2GB 三通道结构。
EMMC采用东芝8G高速闪存,型号为:THGBMBG6D1KBAIL。
厂家U盘升级软件与小米电视2 55寸(L55M2-AA)通用,软件采用加密方式绑定主芯片唯一ID,更换主芯片或更换EMMC都需软件重新绑定,小米公司提供的U盘升级包为OTA用户升级包,能解决一小部分软件问题,但U盘升级包升级不好的情况下,只有一条出路,写入iFix团队制作的量产软件!
从市面上反映回来的信息看,不少用户咨询是否能关闭开机广告,所以量产软件特地采用低版本UI制作,无广告纯净版,如果需要升级到高版本,连接网络自行升级即可。
下面给大家介绍一下,维修此板需要掌握的一些知识。
串口打印:直接通过VGA口与编程器连接,线序为第一组,开机正常打印信息如下:
MIU0_DQS-OK
MIU1_MIST0-OK
BIST2-OK
_U
Relocation Offset is: 01100000
[AT][MB][start ub][352]
U-Boot 2011.06-00000-gdd6b2c3 (Jun 20 2017 - 01:49:44)
create instance at 57c75020 with private size 52 bytes at 57c75068
uboot held at [578ddf60~59300000],size=01a220a0
CPU  : Monaco
Board: BD_MST068D_10AHP_14222
HARDWARE ID: 0x4
DRAM:  915 MiB
Now running in RAM - U-Boot at: 58300000
eMMC: HS400 200MHz
eMMC 7.28 GB [E8FFF8h]
db_table=1
No tcon_iic_read_ok
HARDWARE ID with mirror: 0x204
MAC:  0x10: 0x48: 0xb1: 0xaf:0xfd: 0x13
[CPU INFO] cpu opencreate instance at 57c85528 with private size 44 bytes at 57c85570
CPUIoctl - MDrv_CMD_CPU_QueryClock
[UTOPIA INFO] close moduleNames[38]: MODULE_CPU
cold boot,boot reason:wake_src is 0
turn on led
tp_led_enable 42 failed
tp_led_enable 50 failed
tp i2c receive error
msIR_Initialize
AC on
[AT][MBoot][Driver Init][490]
MPOOL size : 0x200000
Writing to MMC(0)... 128 blocks written: OK
done
Changelist:        24543697
fore uup IRKey [0x0]
tp_get_version 108 failed
SAR key = 255
AC on
dl_firmware
mmc change mount : system
Size of file "etc/bluetooth/BCM43569A0.hcd" from mmc device 0 partition system: 47770 bytes
Loading file "etc/bluetooth/BCM43569A0.hcd" at offset 0x0 from mmc device 0 partition system
47770 bytes read
File Length: 47770
start
run_dl_fw() -- start to dl fw
run_dl_fw() - download FW done
mmc change mount : tvinfo
Size of file "wake_on_ble.conf" from mmc device 0 partition tvinfo: -1 bytes
wake_on_ble.conf get size failed
build_rc_command failed with -1
mmc change mount : tvconfig
Loading file "/config/PM.bin" at offset 0x0 from mmc device 0 partition tvconfig
24575 bytes read
Wait for PM51 standby...........PM51 run ok...........UART_115200
STR_ON
_U
[AT][MB][start ub][331]
CPU  : Monaco
HARDWARE ID: 0x4
DRAM:  915 MiB
eMMC: HS400 200MHz
db_table=1
No tcon_iic_read_ok
cold boot,boot reason:wake_src is 5,wakeup pin(INT) is high
bt wakeup gpio level is high
turn on led
msIR_Initialize
DC on
In HAL_AUDIO_SetDspBaseAddr, line(4736), u8Index(0x0), u32Bin_Base_Address(0x0), u32Mad_Base_Buffer_Adr(0x3ab97000)
In HAL_AUDIO_SetDspBaseAddr, line(4736), u8Index(0x1), u32Bin_Base_Address(0x0), u32Mad_Base_Buffer_Adr(0x3aa17000)
In HAL_AUDIO_SetDspBaseAddr, line(4736), u8Index(0x2), u32Bin_Base_Address(0x0), u32Mad_Base_Buffer_Adr(0x3a197000)
MDrv_AUDIO_SeSystemLoadCode()
[======= initialize DEC-R2[0] SHM =======]
[======= initialize DEC-R2[1] SHM =======]
audio DSP_SE LoadCode success..[[utopia]]       ===  HAL_MAD_SetDecCmd 0 fail===
MusicPath is boot0.mp3
Size of file "/boot0.mp3" from mmc device 0 partition tvconfig: 50890 bytes
Loading file "/boot0.mp3" at offset 0x0 from mmc device 0 partition tvconfig
50890 bytes read
********Amplifier_Init
******Amplifier_TI5717_SWMute(0)
********Amplifier_Init 5717 done
1970-01-01   8:00:00 UTC
is deep night
[[utopia]]       ===  HAL_MAD_SetDecCmd 11 fail===
[AT][MB][Play Melody][1301]
create instance at 57c85528 with private size 344 bytes at 57c85570
MDrv_PNL_Init u32PnlRiuBaseAddr = 1f200000
MDrv_PNL_Init u32PMRiuBaseAddr = 1f000000
LINK TYPE = EXT [MDrv_PNL_SetPanelType][667] ATTENTION!!! Not support HW Training Mode
[MHal_PNL_Init_MOD][2109]Vx1 2 division
[msReadEfuse][1689]u32Result=540000d3, after mask u32Result=40
[msReadEfuse][1689]u32Result=540000d3, after mask u32Result=13
[msSetVBY1RconValue][1725]u16temp= 13
Vx1 2 division[_MDrv_PNL_Init_LPLL][323]pstPanelInitData->u16Width=3840, pstPanelInitData->u16Height=2160
[_MDrv_PNL_Init_LPLL][325]u16HTotal=4400,u16VTotal=2250,pstPanelInitData->u16HTotal=4400,pstPanelInitData->u16VTotal=2250, u16DefaultVFreq=600
@@11=39
[_MDrv_PNL_Init_Output_Dclk][375]pstPanelInitData->u16Width=3840, pstPanelInitData->u16Height=2160
[_MDrv_PNL_Init_Output_Dclk][377]u16HTotal=4400,u16VTotal=2250,pstPanelInitData->u16HTotal=4400,pstPanelInitData->u16VTotal=2250, u16DefaultVFreq=600
@@11=39
@@11=39
[MApi_XC_MLG_GetStatus, 1652]No instance existed, please get an instance by calling MApi_XC_Init() first
Init PWM2[msReadEfuse][1689]u32Result=540000d3, after mask u32Result=40
create instance at 57c856d0 with private size 1788 bytes at 57c85718
[XC,Version][0;36m
[mMApi_XC_Init_U2, 1151, pXC_InitData->stPanelInfo.eLPLL_Type=51
Wait for PM51 standby DRAM ...........PM51 run ok...........mmc change mount : tvconfig
Size of file "/boot0.jpg" from mmc device 0 partition tvconfig: 101722 bytes
Loading file "/boot0.jpg" at offset 0x0 from mmc device 0 partition tvconfig
101722 bytes read
create instance at 57c85e18 with private size 312 bytes at 57c85e60
[AT][MB][JPD Decode][1788]
[UTOPIA INFO] close moduleNames[35]: MODULE_NJPEG_EX
create instance at 57c85e18 with private size 1720 bytes at 57c85e60
[GOP INFO] gop opencreate instance at 57c86520 with private size 7756 bytes at 57c86568
[AT][MB][Show Logo][1856]
[AT][MBoot][Driver Init][1859]
done
SAR key = 255
DC on
[0;34m*******************************[0m
[0;34m* tee Authentication SUCCESS !! *[0m
[0;33mThe version of tee.bin is 00:00:00:00
[0mMPOOL size : 0x200000
[0;34m* boot Authentication SUCCESS !! *[0m
[AT][MBoot][Boot Nuttx][3372]
## Booting kernel from Legacy Image at 25000000 ...
   Image Name:   MStar-linux
   Image Type:   ARM Linux Multi-File Image (uncompressed)
   Data Size:    7346266 Bytes = 7 MiB
   Load Address: 20208000
   Entry Point:  20208000
   Contents:
      Image 0: 5108152 Bytes = 4.9 MiB
      Image 1: 2238102 Bytes = 2.1 MiB
## Loading init Ramdisk from multi component Legacy Image at 25000000 ...
-usb_stop(USB_PORT0)
-usb_stop(USB_PORT1)
-usb_stop(USB_PORT2)
-usb_stop(USB_PORT3)
-usb_stop(USB_PORT4)
   Loading Multi-File Image ... OK
Disable UART
进入三清模式的方法有两种,一种是用遥控进入,一种是控制台下进入。
遥控方式进入:待机状态下,按住红外遥控的主页和菜单键,再按本机的开机键不松,直到出现三清界面。
控制台下进入:按住回车键不松,交流上电进入控制台,输入rec回车,然后输入res回车,自动进入三清界面。
厂家升级方式:厂家提供的U盘升级包两个文件放入U盘根目录,插入主板USB3.0口。然后按照三清模式的方法进入,开始自动升级。
iFix制作的量产软件支持离线和飞线写入,飞线写入时,点位图如下:
发表于: 2018-5-23 18:22:41
谢谢你的分享,好贴必须拜读。
发表于: 2018-5-23 18:28:25
谢谢你的分享,好贴必须拜读
发表于: 2018-5-23 20:25:10
发表于: 2018-5-23 22:06:43
谢谢分 享数据
发表于: 2018-5-24 07:59:43
论坛高手云集,感谢能花这么多时间写出来供大家学习
发表于: 2018-5-24 08:03:41
谢谢楼主分享资料
发表于: 2018-5-24 09:43:52
谢谢分 享数据
发表于: 2018-5-24 10:11:01
谢谢你的分享
发表于: 2018-5-24 10:31:55
论坛有你更精彩。
GMT+8, 2024-4-20 00:21 , Processed in 0.060207 sec., 11 queries .
