查看: 82526|回复: 36
RT809H编程器技改通知
发表于: 2018-8-7 15:12:22
适用范围:序列号20170715之前,主要是绿色PCB。
Scope of application: the serial number is before 20170715, and mostly the PCB is green.
①软件版本升级到20191216后会自动检测是否需要改动;
1.After your software version is upgraded to 20191216, it will automatically detect whether it needs to be changed or not;
②改动完成后,不需要它提示了,请到RT809H的安装目录(默认路径在D盘,RT809H文件夹),找到“ RECORD.INI ”,用记事本打开后,找到“ TechNotice=1 ”并改为“ TechNotice=0 ”,然后保存,下次打开编程器软件就不会自动打开相应页面了。【特别提醒:好奇宝宝们,其他选项请勿动】
2.After the change is complete, you don’t need its prompt, and then please find out the installation directory of RT809H(the default path is in the D disk, RT809H folder), find out “ RECORD.INI ”, and then open it with TXT, find and change “ TechNotice=1 ” to “ TechNotice=0 ”, then save. Thus when you open the programmer software next time, the corresponding page will not be automatically opened.  [Special reminder: dear curious one, please do not change other options]
处理方法Processing method:
    • 将贴片电阻R26更改为4.7KΩ;
    • Change the Chip Resistor R26 to 4.7KΩ;
    • 将贴片电容C18、C22更改为47uF/10V,更大些容量和耐压的也可,只要不影响安装;
    • Change the Chip capacitor C18 and C22 to 47uF/10V, even larger, as long as the installation is not affected;
    • 没有贴片电容,装电解电容也可以,注意分清正负极性;
    • Without chip capacitor, the electrolytic capacitor is also OK, but the positive and negative polarities must be distinguished;
    • 下图框中电容两端颜色标示:红色为正极、黑色为负极。
    • The color at both ends of the capacitor in the following box is marked with red as positive pole and black as negative pole.
发表于: 2018-10-10 15:33:32
黄雪丽-谢提醒
发表于: 2018-10-12 23:19:40
Thank you for your post.
发表于: 2018-10-14 11:22:02
谢谢版主提醒
发表于: 2018-10-15 17:14:38
谢谢版主通知提醒,我的不用改。
发表于: 2018-10-15 23:32:21
So many thanks.
GMT+8, 2024-4-26 14:17 , Processed in 0.056533 sec., 10 queries .
