查看: 1763|回复: 3
小米L47M1-AA打印信息 是什么问题?
发表于: 2019-2-4 09:31:35
001:  TXD: VGA--15; RXD: VGA--12.
002:  C:\Users\Administrator\Desktop\Print.log
003:  COM4, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15,
msAPI_CEC_Init()
==>g_u8Hardware_Id = 2
chip id:6
Availink AVL6381 Demod!
41 6E 64 72 6F 69 64 20 42 6F 6F 74 6C 6F 61 64
msAPI_Tuner_Serial_Control(bParallelMode=0)
Serial_mode=0
[Msg_SendMenuLanguage] 0x65, 0x6E, 0x67 - eng
79 2 10 0 0 0 0 0 0 1 ED FE _MAPP_EPGDB_Setup: [Current EPG DB occupy size: 0x4F59B0];  [Max EPG DB config. size: 0x500000]
msAPI_Scaler_SetBlueScreen(en=1, c=0, t=200)
[SetBlueScreen=1]--0
AVL6381 Sleep!
====change source=====
DSP code loaded successfully
[devTunerSetFreq]device/tuner/SILAB_2158_A20.c, 1612,  m_OtherMode=4, u32Freq=867875000, CurrentStandard=4
ATV_SetTune freq = 867875; SYS = 3...........
!!!!!!!!!!!!!LOCK..................................
MsVifIffre=2
_TVShiftClk=867875000
Tv shift Clk=0
--E_ATV_CLK_TYPE1_43.2MHZ--
Set Video Standard:0x0 >>> msAPI_Scaler_SetSourceType (1, 23)
========= CUS04_ATV_MM_M12 =========
DVB-T Software Version: 0.00
[Board]: BD_MST6M182_NEST
[Panel]: TTL_1080P60
[Tuner]: SILAB_2158
[Boot Area]: 0
[DRAM TYPE]: DDR2_800
[MEMORY_MAP]: MMAP_64MB
[DRAM SIZE]: 64 MB
[FLASH SIZE]: 8 MB
[ATV]: PAL
[Mirror]: 0
[ENABLE_PWS]: 1
[ENABLE_POWER_SAVING_DPMS]: 0
[DEMO_FINE_TUNE]: DFT_STD_ORIGINAL_SETTING
[ENABLE_DLC]
[FW VERSION]:4.113.E
[FW VERSION]:0.01.003E
=> DC_BOOT (1)
PM Wakeup by SAR
VER[Index0]                     = 0x556
VER[Index1]                     = 0x4C1
CRC32 for chunk header [SW]     = 0x6AD87366
CRC32 for chunk header [HW]     = 0x6AD87366
CRC32 for ap code [SW]          = 0x8592E0A8
CRC32 for ap code [HW]          = 0x8592E0A8
REG_FLAG_THE_BOOT_AREA          >> 0xE0
REG_FLAG_FORCED_TO_WRITE_FLASH  >> 0x0
REG_FLAG_WARMING                >> 0x0
>>CMD:23,2,0,0,0,0,0
===> 6M30_3D_CMD_DataWrite[0]
sellect MFC mode error!!!
79 2 10 5 B6 0 5 56 1 1 D6 FE
[UART2] UART2_SendCommand() current time = 1264
79 3 F 0 0 0 0 0 0 1 ED FE u32IOEventQueue = [0x0] [0x0] [0x0] [0x0] [0x0] [0x0] [0x0] [0x0] [0x0] [0x0]
==> Execute API for return status by Query type of Nest protocol <==----currentInputSource=0---
----nestInputSource=1---
79 3 F 4 0 2 6 0 0 1 E1 FE
[UART2] UART2_SendCommand() current time = 97
Set Video Standard:0x7Set Video Standard:0x0[EventLog] MonitorH79 3 F 0 0 0 0 0 0 1 ED FE DMI() >> GPIO Hi to bHDMI2_Loss & event =80000
 楼主| 发表于: 2019-2-4 09:38:14
[HDMI2 No Signal ]
[EventLog] MonitorHDMI() >> GPIO Hi to bHDMI_Loss & event =40000
[HDMI1 No Signal]
u32IOEventQueue = [0x80000] [0x40000] [0x0] [0x0] [0x0] [0x0] [0x0] [0x0] [0x0] [0x0]
79 3 F 4 15 2 6 0 0 1 CC FE
[UART2] UART2_SendCommand() current time = 31
[devTunerSetFreq]device/tuner/SILAB_2158_A20.c, 1612,  m_OtherMode=4, u32Freq=867250000, CurrentStandard=4
ATV_SetTune freq = 867250; SYS = 3...........
79 3 F 0 0 0 0 0 0 1 ED FE u32IOEventQueue = [0x40000] [0x0] [0x0] [0x0] [0x0] [0x0] [0x0] [0x0] [0x0] [0x0]
79 3 F 4 14 2 6 0 0 1 CD FE
[UART2] UART2_SendCommand() current time = 92
[devTunerSetFreq]device/tuner/SILAB_2158_A20.c, 1612,  m_OtherMode=4, u32Freq=866750000, CurrentStandard=4
ATV_SetTune freq = 866750; SYS = 3...........
[EventLog] MApp_SetS79 3 F 0 0 0 0 0 0 1 ED FE rcListFlag() >> GPIO Hi to bAV_Signal_Loss & event =20000
[AV No Signal]5
u32IOEventQueue = [0x20000] [0x0] [0x0] [0x0] [0x0] [0x0] [0x0] [0x0] [0x0] [0x0]
79 3 F 4 11 2 6 0 0 1 D0 FE
[UART2] UART2_SendCommand() current time = 23
[devTunerSetFreq]device/tuner/SILAB_2158_A20.c, 1612,  m_OtherMode=4, u32Freq=866250000, CurrentStandard=4
ATV_SetTune freq = 866250; SYS = 3...........
Set Video Standard:0x7 msAPI_Scaler_SetBlueScreen(en=0, c=0, t=200)
[g_getcurrent=50--g_startmute=0--]
[EventLog] msAPI_S79 3 F 0 0 0 0 0 0 1 ED FE caler_SetBlueScreen2() >> GPIO Hi to bTiming_Change2(Disable) & event =100000
[SetBlueScreen=0] --- 12
u32IOEventQueue = [0x100000] [0x0] [0x0] [0x0] [0x0] [0x0] [0x0] [0x0] [0x0] [0x0]
----currentInputSource=1---
79 3 F 4 16 6 6 0 0 1 C7 FE
[UART2] UART2_SendCommand() current time = 155
79 2 11 0 0 0 0 0 0 1 EC FE >>
79 2 11 1 32 0 0 0 0 1 B9 FE
[UART2] UART2_SendCommand() current time = 127
[devTunerSetFreq]device/tuner/SILAB_2158_A20.c, 1612,  m_OtherMode=4, u32Freq=865750000, CurrentStandard=4
ATV_SetTune freq = 865750; SYS = 3...........
fWaitforMSGBoxFading = 1
79 1 14 1 2 0 0 0 0 1 E7 FE >>
79 1 14 1 1 0 0 0 0 1 E8 FE
[UART2] UART2_SendCommand() current time = 4
发表于: 2019-12-13 15:49:26
我的打印也是这样.5 12v都有,蓝灯闪
发表于: 2020-1-19 13:03:25
!!!!!!lock  是不是上锁了
GMT+8, 2024-4-26 13:45 , Processed in 0.055047 sec., 9 queries .
