查看: 968|回复: 2
809F打印信息乱码
发表于: 2019-4-17 17:33:58
在爱修网淘宝店买的VGA转接线接创维9R10的板子,看打印信息出来的都是乱码,但同样用这根线看8S51的板子的打印信息又是正常的,换了创维的工装再看9R10的板子的打印又是正常的,这把我搞蒙了,是哪里出了问题,顺便请教一下这个打印信息显示的问题在哪里。原来的故障是不重启,清空了EMMC,再写引导后升级升不进去。
A
U-Boot 2012.07-svn620799 (Jan 22 2014 - 10:14:50)
GPU : BISR testing...
GPU : Finish BISR testing (OK)
SCPU: BISR testing ....
SCPU: Finish BISR testing
CPU  : Cortex-A9 dual core
Media: eMMC BP0
MISC : set FUSE_RDY
MISC: efuse had NOT been written
DRAM:  1 GiB
Watchdog: Enabled
init_amp_prepare
Board: Tv010 v2 1G Board E690
POWER ON: AC
Cache: Enabled
Non-Cache Region: 1 MB@0x07900000
MMC:
emmc:mmc_initial(1) Jan 22 2014 10:15:07
RTD299x eMMC: 0
Device: RTD299x eMMC
Manufacturer ID: 11
OEM: 100
Tran Speed: 52000000
Rd Block Len: 512
MMC version 4.0
High Capacity: Yes
Capacity: 3.7 GiB
Bus Width: 8-bit
Extern param: MMC blk:0x7c (to 0x9000)
         rtk_eMMC_read blk_addr=0x0000007c, data_size=0x00000800, buffer=0x00009000
Factory: MMC
         rtk_eMMC_read blk_addr=0x0000c000, data_size=0x00000200, buffer=0x07880008
         rtk_eMMC_read blk_addr=0x0000e000, data_size=0x00000200, buffer=0x07880008
[FAC] No factory data in eMMC
get_bootparam:
------------can't find tmp/factory/bin_panel/000BootParam.h
boot_power_on_mode=1
get_layout:
------------can't find tmp/factory/layout.txt
init_amp
[ENV] read_env from factory failed
[ENV] Using default environment variables
Panel: Use default config (tmp/factory/bin_panel/panel.bin is not found)
Panel: default_panel.h
panel_init_1st
Panel: ulFreq:149000000, nDPLL:157499520, Mcode:35, Ncode:3, offset:6e9
DispI : Finish BISR testing done
DispD : Finish BISR testing done
Net:   rtl8139: REALTEK RTL8139 @0xb8016000
Hit Esc or Tab key to enter console mode or rescue linux:  0
------------can't find tmp/factory/recovery
======== Checking into android recovery ====
boot_ac_on=1
stopping USB..
Start Boot Setup ...
         rtk_eMMC_read blk_addr=0x00010000, data_size=0x00000020, buffer=0x06ff0000
[ERR] rtk_plat_read_fw_desc_table_from_eMMC:Signature() error!
panel_init_2nd
ampinit at panel flow, 2955
wuhaha panelid = 0
init TAS5711 (2995)..
err!UINT8Adr=[0x1b],UINT8DataLen=[1]
err!UINT8Adr=[0x6],UINT8DataLen=[1]
err!UINT8Adr=[0x8],UINT8DataLen=[1]
err!UINT8Adr=[0x9],UINT8DataLen=[1]
err!UINT8Adr=[0xe],UINT8DataLen=[1]
err!UINT8Adr=[0x19],UINT8DataLen=[1]
err!UINT8Adr=[0x7],UINT8DataLen=[1]
err!UINT8Adr=[0x14],UINT8DataLen=[1]
err!UINT8Adr=[0x13],UINT8DataLen=[1]
err!UINT8Adr=[0x12],UINT8DataLen=[1]
err!UINT8Adr=[0x11],UINT8DataLen=[1]
err!UINT8Adr=[0x3],UINT8DataLen=[1]
err!UINT8Adr=[0x1a],UINT8DataLen=[1]
err!UINT8Adr=[0x20],UINT8DataLen=[4]
err!UINT8Adr=[0x21],UINT8DataLen=[4]
err!UINT8Adr=[0x25],UINT8DataLen=[4]
err!UINT8Adr=[0x52],UINT8DataLen=[12]
err!UINT8Adr=[0x29],UINT8DataLen=[20]
err!UINT8Adr=[0x2a],UINT8DataLen=[20]
err!UINT8Adr=[0x2b],UINT8DataLen=[20]
err!UINT8Adr=[0x2c],UINT8DataLen=[20]
err!UINT8Adr=[0x2d],UINT8DataLen=[20]
err!UINT8Adr=[0x2e],UINT8DataLen=[20]
err!UINT8Adr=[0x2f],UINT8DataLen=[20]
err!UINT8Adr=[0x30],UINT8DataLen=[20]
err!UINT8Adr=[0x31],UINT8DataLen=[20]
err!UINT8Adr=[0x32],UINT8DataLen=[20]
err!UINT8Adr=[0x33],UINT8DataLen=[20]
err!UINT8Adr=[0x34],UINT8DataLen=[20]
err!UINT8Adr=[0x35],UINT8DataLen=[20]
err!UINT8Adr=[0x36],UINT8DataLen=[20]
err!UINT8Adr=[0x5a],UINT8DataLen=[20]
err!UINT8Adr=[0x5b],UINT8DataLen=[20]
err!UINT8Adr=[0x3a],UINT8DataLen=[8]
err!UINT8Adr=[0x3b],UINT8DataLen=[8]
err!UINT8Adr=[0x3c],UINT8DataLen=[8]
err!UINT8Adr=[0x3d],UINT8DataLen=[8]
err!UINT8Adr=[0x3e],UINT8DataLen=[8]
err!UINT8Adr=[0x3f],UINT8DataLen=[8]
err!UINT8Adr=[0x40],UINT8DataLen=[4]
err!UINT8Adr=[0x41],UINT8DataLen=[4]
err!UINT8Adr=[0x42],UINT8DataLen=[4]
err!UINT8Adr=[0x43],UINT8DataLen=[4]
err!UINT8Adr=[0x44],UINT8DataLen=[4]
err!UINT8Adr=[0x45],UINT8DataLen=[4]
err!UINT8Adr=[0x46],UINT8DataLen=[4]
err!UINT8Adr=[0x5],UINT8DataLen=[1]
ee read 368, 6
name=EEP_I2C ppcb_enum.Name=EEP_I2C, ppcb_enum.info=4
EEP_I2C=4
name=EEP_DEVICE_ADDR ppcb_enum.Name=EEP_DEVICE_ADDR, ppcb_enum.info=50
name=PIN_EEP_WP ppcb_enum.Name=PIN_EEP_WP, ppcb_enum.info=100011304
m_PIN_EEP_WP = 0x100011304
a. Eeprom_Read-macaddr is bcec2342a4c7
set_mac_cmd is bc:ec:23:42:a4:c7
#@# do_usb(481) is_usb_ac_on 0
(Re)start USB...
USB0:   #@# usb3_phy_setting(108) +++ 20130826
#@#  usb3_phy_setting(209) ---
#@# usb2_phy_setting(214) +++ 20130823-1
#@#  usb2_phy_setting(322) ---
#@#  usb3_mac_setting(329) +++ 20130510
#@#  usb3_mac_setting(412) ---
Register 5000140 NbrPorts 5
Starting the controller
USB XHCI 1.00
scanning bus 0 for devices... usb_init 104
#@# usb_hub_configure(515) skip the device in usb3 port 5!
usb_init 113
2 USB Device(s) found
       scanning usb for storage devices... 1 Storage Device(s) found
XHCI timeout on event type 33... cannot recover.
BUG: failure at xhci-ring.c:549/xhci_wait_for_event()!
到这里机器又重启了。
 楼主| 发表于: 2019-4-17 17:36:14
这个是乱码时的显示
2019-4-17, 17:16:4
COM2, BaudRate:115200 bps, RXD: VGA->15,TXD: VGA->12, Printed by RT809F:
踇鹠?圻?圹w{圹慧??9k趸?究g鹖葵7啕?韄葵??锘啕粂?丝o镲藒o稃锘燐9?om韀o{z倏稞燐{y箉k脎?鏜{{山oi?{鱫?麀鸞宽髹锘镲韂O唠埯?踇畸羡o臌榭{劭w?}鸰o辂'锟鹹锘??蹮{圯郫劭彐轱[簌塍齅_?o肟onk?koo靠?炕埏埯_o斤蹧肟粺豢縲櫉綗{{鄢縪浗匡閛閧?[踇镫遫臌臌圹m?埯埯Kk雓?y鹢埙{韔{呖?_葵鹻{o{o埏{升线骰??鬟靠?浄/縶?宽踇睇氽m咣圻_飡咣圻髹k哌唢k埯縤鹠靠靠_镫靠w=鞬;o靠畸喵??眄靠9穥稃炕?{匡镗{鹻懑矸?镲镲踎縪{縶O{飋/輘襟莸隷o輔齩踥粇?osm?磉薿傀o匡[鹠{焮oo亏埯??踡燐僳鹢葵?劭o鹠踇[oo?o圹幺o?镗魁??鼯{3{[?呖繜?霪o譡镫縪{?繜??{伙??韂o斤Kk羡垭垭呋o圹焚埯?m圻圻?圹踜圹???鼷?黧=???縪??匡畸刍?o鬃黩篼鱷髎稃??稃鼢篌楓鱯?[篌蝮篌{碹镲;葵欙稃[稃亠鹢?颻?埯?侩{睇臌臌臌k???鬯黠扣颷稃炕豢髶娇?o铒鬯隣'靠??[埯k{膂?凤稃冯腚腚腚腚腚k锘啭鼋葵扣??郫哌??刍遻遫麩檫圻逫o??甥s稃?鹒飉{_7?锘燐?埏?贿丝豢畸?o铒?锟浑稃埏蹮{圹鼷鱫髹岿锵{锝莎?豢豢豢换莎畸m稃箍櫩畸?鹢o[驒扣?畸?鬯?睨{臌遻{鸞辋o塍牖刍{脎髹蝮篌篌s鵱鱋??>;;?2緉~o镗脎鹲鹹峡脎s蹧锟?镛ki{{憝镲腚kooi巾锟击穗腠颻k睐;伙稃雥{?稃燐?靠?窟{埏锘宽臌唢靠咣?锘??w咣鶬;鹻掑н涍騸焴9?;?>?馅om匡飋o箍oom匡麢葵交他{踸炕葵m葵葵{?{镯y臌k臌埯k[鹻km啕?圹咣镞宽o籵咣锟镯鬯克靠=镲{?贩眄縶眄_丝?靠????脎?脒o稃縴脎鹢飉踸粵?脎>-_克克鬯靠鹢痬踜郴?m鵼颷}韔颷靠}锆换望头?}韠?韔颷靠埯oO丝妄消矿[mk[o胭圹踇圹埯踜扣圻?k{僳桔籵?{鹻统畸縨鵢?韔颷靠镲o髹蟑埯[?鸰克扣靠?o葵粄w?oo?o克克麠鹻畸{7蹞zk韘鵞=镺克鬯靠埯斤煌换蠼=鸞=鹢頪靠斤煌换髛i劭垌臌扣o鹻o綤哆k鹻圻圻圹?{畸o_ii哌7坶镗埯{}谶镗克靠o飉垌?7蠼靳[}磉克克靠o飋?髹索熆?葵{镲麩畸踸w他埯?锟劭镲鹻隣'靠?镲埯趝韔葵粺?{~穗__?o锼埯甥埯哇箍基{?{圹{{豢}[遻_贿刍埯?劭塍埯戏呦遊o?哌警?黩s圹克驰篼{碹[/稃縪/箋?橱o匡?凰豢?{澺矶{?丝?~oyy[飣?Oo?K捱桔[{跭oK啕O_K薿遦?{?炕痮遦坶?{i7o圹簌邵?k痭黹縰9化眄?埤??k垠?埘?[?线??俘脒?炕埘o绛雜麩{s{陲箫??辇?/?炕埘?o珉怂趝彻陲箫??i唧忒腚m?}W作吊膈?斫唔絎??觚眄[他?埘??閩髈??埘_[箍k谯埘埯??啐侩遳箍瘂m焳岿?篼叻}i?o;抗埙o餄怂锃谯?{冠秣稃踺im無o?炕圯?遊埏i麩{硑陧?肟将黪]?韠o飡稞io韞睇碉?痮踂雓邿?9垌筮i谶籵锘葵埘o锟讼稞i?縴?锘埤齙睇燐???埯?圳緁禁齩锃怂颹I跓{穣陧箫埯镯圳s镗o葵o锝怂稞i诳?稃??韀啕哌圻环_踜脎呋鼷埯废睚{呖?羡迺o縪{y縦圻?垌箫?粉?????鳚僳飣k线oo?踼o?{筼k焳硔揄笏埯憝m鷕o?炕踰?o珥怂镩k跓{3y埏笏锃i蹮o锘炕踰?o餄僳圹鹻圻圻檫磉哌鹽圻鱫?扣圹房哌?o踳?燋o锘炕鄣鼷o锝怂?脎燐岿垌髹???劢???o哌圻s?慧劢?o?{9;i{埤?埘笏??i蘅r?豢?劢篼o?构痠诳埯?埘笏??i跓镲k葵?埯{{y[咣畸穥?]椷臃鷞晨?}O雘o{踸?_??魉??i邝?;?劢?o?羡蹮观矬稃眄畸埤k?讹陧黠?o?o鱫蹧熯_铽怂镙i蹮?陲箫埯锃i蹮o?炕鄣篼o餄纤稞i劭诨诉稃羡齩k齥o雘踥?[唔遾[韔?唔?[脎髹巛?k跓O[埤黠镯鹢锘炕劢?o?y稞线锟膑??劢_镗齥葳浰垌?{?i跓鎜锘炕劢篼o巛怂锃i诳埯?埘???k谶3o??鄣篼?瓄[?o飡k[腴{稃{[穗唠mKk達雘{[雖齧?鲎ok頍穙?趸埤?飋构}k埯?埤镞{籵;?_飋?哌埏跨?{摭鹢粉削剿孙鵲?讹陧笙{椵i蹮稃??埘?o缃怂稞i蹮{饭埏箫??i诳螓?魁ok镯K憝氕烬韐o殚?o_k眄[臌=okko{y锟飋盹?埘韎蹮o?葵蹮達飋还宽呖??镯邴豢?埤晓蝶?y躇埤麤积mo?u珉圹餄i诳{sy陧篼i繜o?莼踰?o稞僳镩i?y?鼷痥oK稃o憝腚韐?給稃o{靠o?縨煭辇蹮彻埏?m谶{o锘埯呖o靠???稃粉_锟?}呖~縪??鬯?扣煼~{{?踜圹鼷騵臌?縦垓{踸靠鹻唠{?縪??炕=锟?{}_臌}睇鹝絢臊腚懑葵轱k腚腚i?醌齗髯?符浇镲腚鹝??窡縪??炕劭垠?圹埙{睇镗???????酃/豢?镲浛薻o巯匡圹蠓埯圻{邴Ё'圯葵{?镗郫稃娠雥想蹧域撚摞埏涆_??羡?跧垌/o飋憝璵江稞m{k_k咣??i睇kkk鸞绡飋?稃粺黧埯{臌3净?>环??锼?镗鹢竭{韔o岿锵圻劭m燐消髹輔?圻篌捽{伙?嚣锼?觖?镗縨羡梍mi?o?o锓{?镗粺踇}睇腠眄?腚k拷殡巾稃江??臌镫oikkkk锆瘆_?縪愤他?{圹鹢匡韠?m冫鹻埯丝换薩{?7?盹飋匡?鹹锟熆?氽峡飾傀??騵屣[[颵蟴]葵郫?埯垸惋扣镲畸o飛[葵_镗?????m櫩??>?{颻郫粺锼克劭孙熆扣锘箉?縖呖埙{葵锆鶛?畸宽_O/轾葵?伙圻踎{[o?m埯镞呖浑鄱縖鹢o锟?鹝范~啕O{[炕锟??炕炕匣?o燐o贩镯/锟?啕镲o??????
GMT+8, 2024-4-26 09:30 , Processed in 0.069988 sec., 9 queries .
